Writing features to ArcGIS Online
  • December 14, 2022
  • 7 replies
  • 695 views
anne_kathr1ne
Im trying to write approx 17.000 rows into an existing feature service in AGOL. I get the error "entity too large for url", so I assume its too many rows. I have tested with a few rows, and that works fine.
I have tried now to use the ModuloCounter and a TestFilter to split into smaller groups, and then add multiple AGOL-writers, so they only write one group at the time. Im not sure this is the best way to go, as I would the need a lot of writers.
imageAnother is to use the FeatureWriter to do the same, but I would still need to do the setup for all the groups, so not sure if thats ideal.
Does anyone have any better suggestion?
Best,
Anne Kathrine
Best answer by tomfriedl
sometimes less is more, the help writes:
Features Per Request
This parameter specifies the maximum number of features that may be present in a single write request to the server. This limit applies to Insert, Update, Delete, Upsert, and truncation. The writer will issue a request to the server whenever a single feature type accumulates the number of output features specified by this parameter.
Note: This parameter is only applicable when writing to an existing Feature Service. If the Feature Service was created in the same translation, then this parameter is ignored.
This parameter is useful for avoiding server timeouts or HTTP 500 responses that may result from long write operations.
If this parameter is not provided, it defaults to 1000.
tomfriedl
Forum|alt.badge.img+13
  • December 14, 2022
Have you set the writer-parameter "Features Per Request"?
anne_kathr1ne
  • December 15, 2022
Hi @tomfriedl​ , yes, I added as many 0's as I could, just to make sure :)
tomfriedl
  • December 15, 2022
anne_kathr1ne
  • December 15, 2022
Hi @tomfriedl​ Im not sure it will help adjusting, since I anyway gets an error when trying to write less features than what is specified. So I think I need to find a more neat way to write data in smaller groups.
anne_kathr1ne
  • December 21, 2022
Hi @tomfriedl​ ,
You were right. It worked fine adjusting the features pr request to 100. I think I just needed a few days to sink in what you actually suggested! ;)
matthewb
Forum|alt.badge.img+10
  • June 28, 2024
I’m having the same error, even when I dial my process down to 10 features per request.  Are there other processes that could be modified to improve this performance?
jaywood
Participant
  • Participant
  • November 17, 2024
I was facing similar issue. Writer Mode to Asynchronous with Report Yes and Time Out 300 fixed this problem
