Writing aggregated features in AutoCAD
  • Jul 26, 2017 7:19 AM UTC
  • 123 views
zzupljanin
Forum|alt.badge.img+5
if you try to write aggregates in AutoCAD you'll get block, which is kind of unwieldly, especially if you need to modify geometries in AutoCAD.
As it looks like groups can't be written (only read) using FME.
I'd like to ask you, what are your experiences with this. Are there some other workarounds...
Thanks in advance,
Želimir
Best answer by fmelizard
If you want to see FME support writing groups you can vote on this idea
If you have polygons which are getting turned in to aggregates consider using converting them to MPolygons with the DWGStyler. This will at least keep the aggregated areas together.
If you have multiple geometry/entity types in your aggregate then it could be worth deaggregating these and then writing them all on a unique layer per aggregate.
lars_de_vries
Forum|alt.badge.img+10
Hi @zzupljanin,
up to my knowledge, AutoCAD does not support aggregate features, except for Block definitions and perhaps for Solids and Hatch objects.
Hope this helps.
fmelizard
Forum|alt.badge.img+22
  • Jul 28, 2017 10:40 PM UTC
gio
Forum|alt.badge.img+15
  • Jul 29, 2017 2:49 PM UTC
ad an extended attribute to the objects.
You can use search (properties tab) in autocad to aquire or group them.
zzupljanin
  • Jul 31, 2017 11:21 AM UTC
They also can't be modified easily... I think it is best it can get for now.
Thank you everyone
