Write Source Pathname to SHP file Attribute
  • Dec 11, 2012 8:35 PM UTC
  • 69 views
Hi....I need to figure out how to write the source path name of a file to the attribute table of a SHP file. I wanto to do this to generate field hyperlinks in the SHP file.....I can expose the format attribute "fme_basename" to get the filename, but I need to write the entire path out.....can anyone point me in the right direction.....Thanks....Scott
  • Dec 11, 2012 8:44 PM UTC
Wow....I post the question and then the light bulb comes on......you use the format_attribute "fme_basename" to get the full path.....Scott
  • Dec 11, 2012 8:46 PM UTC
sorry again....."fme_dataset".....:)
fmelizard
Forum|alt.badge.img+22
  • Dec 12, 2012 7:25 AM UTC
Have a look at the Directory and File Pathnames reader too.
Hope this helps.
Itay
sigtill
Forum|alt.badge.img+25
  • Dec 12, 2012 8:13 AM UTC
You can use a ParameterFetcher to fetch Published Parameters. So if you convert the INPUT-file on the READER to a Published Parameter you can fetch this in the workspace.
