Write polylines with attributes in Microstation DGN v8 XFM
  • September 5, 2018
  • 0 replies
  • 18 views
About possibility in FME Workbench to write in Microstation DGN XFM format, linear elements (polylines) with attributes for a dataset that have lines with elements but other format not supported by Microstation. I need to be able to see in Microstation Bentley Map the polylines and their attributes. Currently, I have the lines and their attributes in MS access format for Geomedia and ESRI and would be great to be able to export them in DGN with XFM attributes. DO you have any advise on that? Thank you! Lavinia
