Hi everyone,
is it possible to write pointcloud features to 3D PDF? When I try to do so all I see in the pdf is the bounding cube of the pointcloud feature but no points itself.
In case 3D PDF is unable to display pointclouds properly, is there a workaround for this issue? I played around with 3D spheres that are located at every 3D point - position but that forces 3d PDF to its knees with not more than 10.000 points/spheres which is rediculous less for pointcloud data and therefore doesn't seam to be a suitable way.
Attached a small sample of a pointcloud feature
