Write google fusion table to a specific folder on Google Drive?
  • Jan 27, 2014 12:41 PM UTC
  • 5 replies
  • 76 views
Is it possible to specify an existing output folder on Google Drive when writing to a Google Fusion table? It always ends up in the root folder (My Drive) for me. I would like to write the table to an existing shared folder to avoid having to share the table when it's written.
/mats
fmelizard
Forum|alt.badge.img+22
  • Jan 27, 2014 1:01 PM UTC
Hi Mats,
I dont think so, but you can create the table, move it via google to the desired location and re import it into the ws.
Itay
  • Jan 27, 2014 1:59 PM UTC
Thank you Itay. I need to drop and recreate the table every time I run my ws and then the new table is created in the root. I would prefer not having to do the move operation every time. Where do I file an enhancement request?
/mats
fmelizard
  • Jan 27, 2014 2:37 PM UTC
Hi Mats,
I guess you can just request support and Safe should pick it up....
I basically only move the final table/map to the desired location and do my testing in the root, this way you only have to move the final product once.
Itay
  • Jan 28, 2014 12:37 PM UTC
Hi Itay,
Yes, your solution works ok if it's a one time job. My situation is that I run a workspace weekly on an FME server and don't like having to log in to Google Drive once a week just to move the file.
I tried to truncate the file instead of dropping it, but it seems to be very unstable. The workspace often fails after a few hundred records.
/mats
  • Jan 29, 2014 10:09 AM UTC
Hi Mats
We cannot currently specify a Google Drive folder when creating a new Google Fusion table - I filed a task to look at doing this.  If the table exists we can write to it whether or not it is in a folder - but I guess you noticed that.
