write data to different Sheet
  • Oct 22, 2017 12:31 PM UTC
  • 6 replies
  • 164 views
boubcher
Forum|alt.badge.img+11
we want to save data in one excel document but with multiples sheets, each one will have a specific group of features
please sheet the attached Image
  • Oct 22, 2017 2:16 PM UTC
Hi @boubcher, if you set the fme_feature_type_name attribute to the Sheet Name field in the Excel writer feature type, each feature will be written into a sheet whose name is the same as the attribute value. See also here: Setting Feature Type Fanout
boubcher
  • Oct 22, 2017 2:40 PM UTC
Hello Takashi
Thanks its now creating sheet for every data group, but I have no idea why it's duplicating the data ,I trayed o play multiple combinations with Feature type Dialogue but with no result
Any idea
Forum|alt.badge.img+63
Hello Takashi
Any idea
If you check the writer parameters in the Navigator there's one, for Excel, that says "Overwrite existing file", it's set to "No" by default which means each time you run the workspace it appends the results to the file, rather than writing a new copy.
boubcher
  • Oct 23, 2017 12:00 PM UTC
Thanks ,
We did set the overwrite option to yes, but still, we are getting the data duplicated (exactly 4 times)
No idea how this possible?
Attached the work space
extact-transportation-schema.fmw
  • Oct 23, 2017 4:02 PM UTC
Thanks ,
You have removed "TransportationZone**/" (** = 36, 37, 38, 39) from the values of "fme_feature_type_name". If there were "TransportationZone36/BusStation" and "TransportationZone37/BusStation" originally, naturally "BusStation" would get duplicated after translation.
boubcher
  • Oct 24, 2017 9:03 AM UTC
Thanks TAKASHI , no idea how we missed that
