Workbench to write shapefiles to Oracle
  • February 12, 2013
  • 7 views
jhawks
Forum|alt.badge.img+7
This should be easy but I'm getting conflicting answers/stories. I want workbench to write shapefiles into oracle 11g in such away that arcmap can than access them (to then create an AGS REST serivce). Do I want an SDE write or an Oracle writer?
fmelizard
Forum|alt.badge.img+18
  • February 12, 2013
If you have a SDE environment with oracle, then I would use the SDE writer to avoid format/environment related issues.
Hope this helps.
jhawks
  • February 12, 2013
I need a special license for that correct? A coworker sent me a license string for it. So now I send my mac address to safecodes and they give me a lic string just for SDE writer?
fmelizard
  • February 13, 2013
I belive you need to have a different FME edition for ESRI compatability, see also the writer licencing level
