Why the File Copy writer doesn't log an error when the file doesn't exist?
rbovard
Hi there!
Do you know why the File Copy writer doesn't log an error when the source file doesn't exist?
It only logs an warning:
File Copy Writer: Ignoring the destination filename '<file>' because the source dataset '<path\to\file>' was not a file.
It was problematic in my case because I monitore only the errors in the log files... :/
Thanks in advance for your feedback,
Rémi
Best answer by ebygomm
Do yu have this parameter set?
Forum|alt.badge.img+38
  • April 23, 2020
rbovard
  • April 23, 2020
Oh, you're a genius! Thanks a lot for this amazing quick answer!
