Why doesn't FME Desktop write all the selected parameters to a CSV file?
  • Apr 22, 2017 3:32 PM UTC
  • 123 views
I have a workspace in which I have selected a CSV file writer to contain the results. The user parameters selected to be written appear in the CSV file. On the other hand, the format attribute (fme_text_string) I have selected does not appear in the CSV. All the results appear in the data inspector, and for a workaround I am forced to select the data in the table and save it to a file from there.
What am I doing wrong?
ciarab
Forum|alt.badge.img+10
  • Apr 23, 2017 12:25 AM UTC
Hi @michaellampi you need to to extract the information from the format attribute fme_text_string and insert it into a user attribute. Use the attribute manager or creator to create a new user attribute called Text_String for example and use the format attribute fme_text_string to populate this. Once you add the new attribute Text_String into you writer you will now find it in your csv output
itay
Forum|alt.badge.img+19
  • Apr 23, 2017 8:04 AM UTC
Try exposing the fme_text_string attribute in the reader or via an AttributeExposer transformer.
Thank you! It is taking me a while to wrap my head around the UI as well as the terminology, but your detailed answer really helped to clear up my confusion.
