Why does newly created attribute not show up in Visual Preview after run?
  • Oct 21, 2020 12:18 AM UTC
  • 234 views
umapper1
Forum|alt.badge.img+5
Hi there, I'm curious as to why the newly created attribute in my workspace is not showing up by default when I go to the visual preview table view. I've had this happen before but I cannot find what governs this. Is there a toggle? The default behaviour should be that it shows up in the table so I can see that it's been created. I can find it in the list of available columns but it is a pain if I'm having to rerun the routine a lot. Anyone know how to change this? Using ver2020.1 but have experienced this issue on previous versions. Below example of my new attribute "Quality Level".
FME sample image
umapper1
  • Oct 21, 2020 12:31 AM UTC
It actually appears that the attribute is not being exposed. Why would I need an attribute exposer?
nampreetatsafe
Forum|alt.badge.img+14
Hi @umapper1​, sorry to hear that you're experiencing some frustration. I would like to reproduce the issue you're experiencing but will need a bit more information.
Would you mind providing a workflow that demonstrates how you are creating the new attribute (are you using a AttributeCreator, AttributeManager, etc.) and/or describe how I can reproduce your workflow and the sequence of steps you take from creating the attribute to attempting to view it in Visual Preview? You mentioned that "it is a pain if I'm having to rerun the routine a lot" - if you have Feature Caching enabled your workspace should just run from the last updated cache. Do you run the workspace after creating the attribute and it doesn't show up in Visual Preview?
umapper1
  • Oct 27, 2020 5:29 AM UTC
Hi @nampreetatsafe​ , thanks for the response. Unfortunately this is part of a live project so I cannot share the workspace publicly however if you want me to send you the workspace directly for interrogation I can? I've attached another image below. I'm using the AttributeCreator to create an attribute from conditional values. You'll see in the Visual Preview pane the new attribute does not show up by default after running.FME
gisbradokla
Forum|alt.badge.img+27
  • Oct 27, 2020 3:14 PM UTC
double check your attributemanager that the attribute is not set to "Set Value" and the attribute value is blank.
