while adding an .sde file getting error "The error number from ArcObjects is: '-2147220944'"
  • Jul 5, 2021 10:31 AM UTC
  • 255 views
swethabhupathi
Forum|alt.badge.img+5
The error number from ArcObjects is: '-2147220944'. The error message from ArcObjects is: {This version of the Geodatabase client is incompatible with the dataset and cannot open it.
i am using an arcpro of 2.7.3 and fme 2020.2 64bit versions.
steveatsafe
Forum|alt.badge.img+16
@swethabhupathi​ ,
It was nice connecting with you on the other support case you have with us.
On that call, you showed me this issue, which is FME is attempting to load ArcGIS Desktop for Geodatabase SDE but errors, while the other system is loading ArcPro and working fine.
The two systems seem to be configured the same, or appear to be.
  • ArcGIS Desktop 10.8.1
  • ArcPro 2.7.3
  • FME 2020.2.0
Could you do 3 things?
1) Could you create a simple workspace with the Geodatabase Reader on the system that works? Save it. Run it. Copy the log file.
2) Copy the workspace to the system that is failing, and run it again. Copy the log file.
3) Create a case and include the log files and the system information reports.
Please run the System Information Report found here on both systems so we can compare them more directly. Please have your System Administrator run this on both computer systems as you don't have access to the command line and share it with us via a case (Submit a Case).
