Which FME Python option to use?
  • Aug 9, 2019 4:56 AM UTC
  • 70 views
I have an ArcPy script that is simply renaming ~40 datasets in an ArcSDE database.
I'd like to run it once by Master FME workspace is complete (set of workspace runners ), so i had thought of using the Shutdown Phyton Script in workspace parameters. However i am very new to FME and to Python to be honest, so it's all a bit confusing (even after reading the information relation to the Python transformers etc).
Can i simply copy and paste my script into the blank window of the script parameter? i.e. import arc py, list variables, include updates to be made etc? or is there a way of including the file path to the python script that sits on my c:drive and have FME activate it?
Thank you in advance
nag
  • Aug 9, 2019 6:29 AM UTC
Try using python Caller transformer... It may solve your issue.
Forum|alt.badge.img+63
