When will the File GDB Open API be able to...
  • Feb 27, 2018 5:43 PM UTC
  • 43 views
aarcra
When will the File GDB open API be able to read and write a File Geodatabase without completely locking down the database?
We find that only one bench can be in a File Geodatabase when using the OPEN API reader and writer, else we will start getting failures.
When using the ESRI GDB reader/writer, you can have as many operations occurring simultaneously as you want in a File GDB, as long as no one is trying to drop and create a table that is currently in use.
When will the OPEN API be able to do the same?
Thanks!
geosander
Forum|alt.badge.img+7
  • Feb 27, 2018 5:53 PM UTC
I don't think Safe Software has any influence here. You'll have to ask Esri. But they'll probably just tell you that you have to use the ArcObjects R/W (else they wouldn't sell any licenses ;))
