I noticed that my connections to my FME Cloud websocket timed out after 2 minutes if no data had been transmitted. I was able to remedy the problem by creating a heartbeat that sent a message at an interval less than 2 minutes. This was a little frustrating to have to work out though.
Is 2 minutes the default timeout on FME Cloud? I had no such issues when using FME Server. I'm guessing this is to do with the settings applied to the NGINX server on the Cloud instances? Is there a way to alter the default timeout, or am I stuck with the heartbeat solution? If so, can you document the default timeout issue somewhere?
