Vertex problems in my Dwg output file in Writer under FME 2018
  • Apr 18, 2020 8:53 AM UTC
  • 0 replies
  • 28 views
Hello,
When I open my Dwg file in autocad I notice that I no longer have any vertex in my output Dwg file after performing the transformations, can you help me recover them? here is my FME file if you could correct it for me or add the transformers necessary for it to work.
thank you in advance
