Varbinary field to PDF
  • May 2, 2018 4:43 PM UTC
  • 7 replies
  • 301 views
I have an application storing PDF's that are uploaded to it in a varbinary field, I would like to reverse this process with FME and extract that data and write the PDF out. So far I haven't been able to get that to work. Any suggestions?
  • May 3, 2018 7:19 AM UTC
Have you tried the AttributeFileWriter?
Be sure to set the target file encoding to "Binary (fme-binary)"
  • May 7, 2018 6:20 PM UTC
@david_r just for clarification it is an image stored in the binary field and want to write that image out to the pdf...in case that confused anyone.
  • May 7, 2018 7:08 PM UTC
So I can at least read the binary field and fme recognizes it now, but when I get to the PDF portion it comes out blank.
  • May 8, 2018 8:01 AM UTC
What does the binary field look like in FME if you send your record to the Data Inspector? Is it empty, or does it contain anything, and if so, how much?
  • May 8, 2018 11:34 AM UTC
504B0304140008000800446F29420000000000000000000000000D0000004A here is the start...1,546,446 characters in the field
  • May 8, 2018 11:42 AM UTC
That's a great start, at least. Can you describe in more detail where the problem occurs? Does the binary field arrive intact to the AttributeFileWriter? How is the transformer configured? What's the size of the output file?
  • May 8, 2018 3:36 PM UTC
Basically I can write it to a file, jpeg, txt, but I can't take it and actually create an image with it that is viewable (or rather haven't figured out how to do that yet)
