Using FeatureMerger to merge Shape and CSV files and write out to GeoJSON produces unwanted attribute columns
  • Oct 9, 2015 7:10 AM UTC
  • 83 views
Hi!
I'm using FeatureMerger to merge a Shape file and a CSV file, and outputting to a GeoJSON file. The merge works as it should, but is producing seven extra attribute columns that I don't want, even though none of the Format Attributes are selected in the Feature Type Properties settings (csv_line_number, csv_number_of_fields, csv_total_number_of_columns, multi_reader_full_id, multi_reader_id, multi_reader_keyword, multi_reader_type).
This is obviously making the GeoJSON larger than necessary. Can someone please tell me how to ensure these Format Attributes don't get written out to the final GeoJSON file?
Thanks!
Best answer by david_r
Hi
Try inserting an AttributeKeeper before the GeoJSON is generated.
David
  • Oct 9, 2015 7:27 AM UTC
Hi
David
  • Oct 9, 2015 7:33 AM UTC
David, thanks ever so much replying so quickly. Your solution works perfectly!
Niall
