User parameter: selecting table from file geodatabase
  • Oct 9, 2024 11:57 AM UTC
  • 196 views
harmen
Forum|alt.badge.img+10
Within the User Parameters I have added the option to Select a File.
More specific the user has the option to select a Geodatabase (Items to Select).
When the user has selected the Geodatabase, I like to have the user also select the database of his/her own choice within that Geodatabase. Is there a way to configure that?
Best answer by harmen
Found the answer shortly after I've posted the question ;-)
Inspired by this post:
How to create parameters for selecting a table (feature type) from an Esri geodatabase (gdb)? | SafeSoftware Community
Not using the option Manage User Parameters, but from within a reader you add user parameters:
harmen
  • Oct 9, 2024 12:08 PM UTC
nielsgerrits
Forum|alt.badge.img+67
...When the user has selected the Geodatabase, I like to have the user also select the database of his/her own choice within that Geodatabase. Is there a way to configure that?
I think you mean dataset or featureclass instead of database. But I do not know of a way to do this other than with predefined values.
