Use of WHERE Clause in Smallworld and SBS Reader
  • July 31, 2019
  • 167 views
Hello,
I use the standard FME Smallworld reader/writer and/or the SBS-plugin to read and write data from and to Smallworld 4.3. A lot of the read actions take a lot of time, due to the very large quantities of objects in our databases.
To make this process a lot more efficient, I want to make use of the 'WHERE Clause'- or 'Where'-function. The idea is, for example, to only read the water mains that belong to the network 'Distributie'.
I first searched this site for some info/advice on how to do this correctly. I found some info and a few examples (example: WHERE Clause: [Electricity] cable where Status = "Accepted"). I also consulted the 'SPATIALBIZ Plugin Usage Guide'. In that guide I found one example of a predicate (example: "gis.hotel where type = 'Hotel'; gis.min_road where road_type = 'A-Road'").
Not really knowing which predicate format is the correct one, I tried a few different predicates ("water_supply.ws_main_section where network = 'Distributie'" and [water_supply] ws_main_section where network = "Distributie"), but with no success. The readers continue to read all data in the database.
Can someone help me out?
Thanks!
Regards,
Luc
erik_jan
Forum|alt.badge.img+26
  • July 31, 2019
This is the section in the Spatialbiz Plugin user guide explaining the where clause for tables:Predicated Data Export
All feature types can be exported based on a selection predicate, defined as a feature parameter. The Export Predicate expects an SQL like statement which will be applied to the retrieval set to restrict the export results.
A very simplistic SQL syntax is supported with the following grammar (see the magik CASE_PARSER) for more information:
predicate
'(' <predicate> ')' |
'not' <predicate> |
<simple-predicate> <bin-op> <predicate> |
<simple-predicate>
bin-op
'and' |
'or'
simple-predicate
<field> <op> <value>
op
= | <> | > | < | >= | <= | like |
is | is null | is not null
String wildcards
% - Any number of unknown characters
_ - A single unknown character
Examples:
name= ‘Test’ and route is not null
  • August 1, 2019
Hello @erik_jan,
Thanks for your answer.
Next to the WHERE tests I did on the entire workspace, I also tested this way of restrictive exporting => see attachments.
None of these tests seem to have any effect. Smallworld offers 40 water mains with 3 different networks, and all 40 water mains get true the reader.
Not really clear what to try next to hopefully get the expected result.
erik_jan
  • August 1, 2019
Hello @erik_jan,
Hi @lucvdberghe,
Can you send me your workspace by email (erik.bodewitz@spatialbiz.com) and I will have a look what might be causing the issue.
Erik
  • August 28, 2019
Hello,
With some help and a bit of testing I got it to work.
What causes this 'problem' is the following.
In most of my workspaces, I place (often pre-queried) data/objects in the SW Explorer under 'Export to FME' (standard plug-in) and/or FME Export (SBS plug-in) => see screenshots.
Applying a WHERE predicate doesn't work once any data is placed there. Not placing any data at all at these locations gets the WHERE -function to work. The plug-in finds the neccesary objects in the correct datastore(s) and applies the WHERE predicate on them.
Problem solved!
