Use of a wildcard in Feature Type to read parameter (single merged feature type)
  • Apr 30, 2014 6:07 PM UTC
  • 171 views
Is it possible to use a wildcard to select the Feature Type to read when single merged feature type option is checked.
I would like to be able to choose what table to read without genereating the list of tables merged in the reader because it takes too much time.
I would like to simply type something like: *711.SHP to select all tables that finish with 711.SHP
It seems it is not possible. Any other solution?
  • May 1, 2014 3:03 AM UTC
As you say, it seems not to be possible to use a wildcard in selecting Feature Types to Read. But you can use a wildcard in Source Dataset parameter setting. For the SHAPE format, file name is same as feature type name. Could it be a workaround?
Takashi
