Use LenghtToPointCalculator on a SHP file
  • Sep 15, 2020 9:10 AM UTC
  • 68 views
Hello
I would like to put points on a single line to use the named transformer and get the length as a new attribute, but it seems that the feature merger used in this example
https://gis.stackexchange.com/questions/30518/fme-calculate-distance-of-point-along-a-line
does not work on Esri Shapefile format, I don't know why.
Any idea on how to fix points on a curve, while keeping each point as a line/different entity in the visual preview ?
Thanks
Edit: MeasureGenerator does not work as the curve has much more vertex than needed and they can't really be sorted
Forum|alt.badge.img+54
  • Sep 15, 2020 10:25 AM UTC
Are you able to provide some sample data? I'm not sure I understand why a process which generates a measure on the line then and then a point on line overlayer to transfer the measure to the point isn't an option here
  • Sep 15, 2020 11:40 AM UTC
Unfortunately I am nto allowed to provide that data, and I do not know how to create a sample on my own.
As for the measures on the line, I do not want to it for each point, and I have no way of separating them as there isn't enough information provided for it. The lines are constitued of multiple verteces but I only want to calculate the length from the start of a single line created with a LineCombiner using them. The problem is that the number of lines from the beginning may vary, but the program must stay the same, and I can't find a way to allow dynamically this number to the uni-line feature that is output by the LineCombiner.
IE
So I have the output of a static calculator with only the count, a line from a Line combiner , and I can't merge the result of the first one into the second one
It sounds confusing, but I do not know how to explain it otherwise, sorry
hkingsbury
Forum|alt.badge.img+73
  • Sep 15, 2020 7:54 PM UTC
Have you looked into the AnchoredSnapper or PointOnLineOverlayer?
https://www.safe.com/transformers/anchored-snapper/
https://www.safe.com/transformers/point-on-line-overlayer/
The issue is unlikely to be the format of the data - when FME reads data in, i'ts converted into FMEs own format. So after a reader it's all the same format (points,lines,poly,raster,pointcloud etc)
