Update reader based on current date
  • April 19, 2018
  • 15 views
I have backup copies of layers in an ArcSDE database, using two digits for the month (01, 02, 03, etc), in order to detect change from the updated versions. Is there a way to have the reader switch to the next month's backup by checking the system date so I only have to press play and not change anything other settings?
erik_jan
Forum|alt.badge.img+26
  • April 19, 2018
You could use this sequence:
Creator (create a dummy object).
TimeStamper (get the current date in the right format).
FeatureReader (read the data based on the timestamp).
Hope that helps.
