Hello everybody,
I have met troubles with values in igds_snappable attribute of cells. In my source datafile (v7), insert point of cell is snappable, but elements of cell are not. When I open datafile in FME Data Inspector, it shows me that insert point and all elements are not snappable.
If I change value of igds_snappable in Microstation for just 2 elements of cell, the insert point in FME Data Inspector is snappable, interesting...
Is it bug or not? Have You ever met the same problem? I´m using FME Desktop 2017.1.2.1
Thank You so much!
Lubo
