Unable to get attributes in DGN file (File GDB to DGN)
  • Sep 12, 2017 5:03 PM UTC
  • 93 views
While translating from File Geodatabase to DGN format i am unable to get the attributes in DGN file...
Help me to get the attributes in DGN file writer?
Thanks in Advance.
Hi @dheeraj
how would you like your attributes to be stored in your DGN? Will they be stored as tags, as text elements (annotations), or as XFM data?
mygis
Forum|alt.badge.img+14
  • Sep 13, 2017 12:04 AM UTC
If you want to set the text as Annotations you would need to:
1. Use the labelPointReplacer to set the location of your text on the drawing/Map
2. Expose the igds_text_string format attribute in the Writer (or any other format attributes you would like to change with regards to the text properties). The igds_text_string will be containing your text. Other text proeprties such as font. size, rotation can also be set using the same method.
I hope this helps.
Cheers.
Lyes
  • Sep 13, 2017 9:07 AM UTC
Hi @dheeraj
Tags only i guess. But while inspecting data in FME Data Inspector i am unable to see any attributes in table below.
