Unable to access Excel file from shared location in FME server
We are unable to access Excel file from shared locationin FME server,
get error "XLSX Reader: Failed to open the dataset 'given Shared path'.  Error message was 'can't open file for reading' ,
but the same excel from local drive we are able to access without error.
Any idea
Regards
CNG
  • August 12, 2014
Hello
Is that path UNC?
Check this
http://fmepedia.safe.com/articles/Error_Unexpected_Behavior/Workspace-Fails-Data-in-Mapped-Drive
  • August 12, 2014
I agree about the UNC issue posted by JohnG.
Also, verify that the account running the FME Server service has sufficient rights to the network share.
David
  • August 12, 2014
after assigning rights to the network share
.its works now , Thanks
