unable to access AGOL after upgrading to FME Desktop 2019
  • Apr 16, 2019 3:11 PM UTC
  • 6 replies
  • 136 views
It gives the error:
Python Exception <FMEWSException>: Type: 3, Number: 1, Message: Failed to get authorization header.
The workbench has been working in 2018 version
rahulsharma
Forum|alt.badge.img+12
Hi @tonyzhang, It appears that your Web Connection needs to be re-authenticated.
If you click on Show Log, it should be more clear
JSON Error: refresh_token expired
Unable to update access token for 'rsharma Esri ArcGIS Online Rahul'
Go to Tools --> FME Options --> Web Connection, Right-Click on the Web Connection Name and say Re-authenticate.
  • Apr 16, 2019 5:16 PM UTC
@rahulsharma
Hi Rahul,
Followed your steps, and I got below:
This site can’t be reached
www.arcgis.com’s server IP address could not be found.
Any suggestions? Thanks!
rahulsharma
@rahulsharma
Hi Rahul,
Are you currently using a proxy server? Can you access https://www.arcgis.com/ in a web browser? Have you set up FME to use a proxy? confirm in under Tools --> FMEOptions --> Network and ensure that Use System Proxy, also add credentials if required. Can you share your log files with me?
palhermans
Forum|alt.badge.img+11
  • Apr 16, 2019 8:55 PM UTC
@rahulsharma, Might be related to the TLS 1.2 update on ArcGIS Online which was rolled out today?
rahulsharma
FME should not be affected, we are currently using AGOL with any issues
  • Oct 8, 2019 4:36 AM UTC
Refresh token helped.
thanks
