Transposing Using the postcode and question number as a pair, possibly a list?
  • Apr 23, 2024 10:25 AM UTC
  • 128 views
sar_copp
Forum|alt.badge.img+5
Morning, I am trying to transpose some data from a survey, I want to sort of Pair up the Postcode and the Question Number, then have columns of Responses with counts. Ive attached imagesΒ  and a fme workbenchΒ of the original data and the output I want. I have 36 questions, so want to know if there is a way to do this using a list? So I dont have to repeat this 36 times, I am not understanding how to do lists!
I want to output the postcode as a column, then have a question number column. So each postcode will be repeated depending on the number of questions e.g.
Question NoΒ  Β  Postcode
Question 1Β  Β  Β  M19 4NY
Question 2Β  Β  Β M19 4NY
Question 1Β  Β  Β  M4 7AT
Question 2Β  Β  Β M4 7AT
Β
Then I want the next columns to be counts of the answers
Question NoΒ  Β  PostcodeΒ  Strongly AgreeΒ  Β  Β  AgreeΒ  Β  Β  NeitherΒ  Β  DisagreeΒ  Β  Β Strongly Disagree
Question 1Β  Β  Β  M19 4NYΒ  Β  Β  Β  Β  Β  Β 2Β  Β  Β  Β  Β  Β  Β  Β  Β  Β  Β  Β  Β 3Β  Β  Β  Β  Β  Β  Β  Β 1Β  Β  Β  Β  Β  Β  Β  Β 0Β  Β  Β  Β  Β  Β  Β  Β  Β  Β  Β  2
Question 2Β  Β  Β M19 4NYΒ  Β  Β  Β  Β  Β  Β 5Β  Β  Β  Β  Β  Β  Β  Β  Β  Β  Β Β  Β  7Β  Β  Β  Β  Β  Β  Β  Β 0Β  Β  Β  Β  Β  Β  Β  Β  3Β  Β  Β  Β  Β  Β  Β  Β  Β  Β  Β  0
Question 1Β  Β  Β  M4 7ATΒ  Β  Β  Β  Β  Β  Β 1Β  Β  Β  Β  Β  Β  Β  Β  Β  Β  Β  Β  Β  2Β  Β  Β  Β  Β  Β  Β  Β  1Β  Β  Β  Β  Β  Β  Β  Β 5Β  Β  Β  Β  Β  Β  Β  Β  Β  Β  Β  Β 6
Question 2Β  Β  Β M4 7ATΒ  Β  Β  Β  Β  Β  Β  Β 3Β  Β  Β  Β  Β  Β  Β  Β  Β  Β  Β  Β  Β 4Β  Β  Β  Β  Β  Β  Β  Β Β  1Β  Β  Β  Β  Β  Β  Β  4Β  Β  Β  Β  Β  Β  Β  Β  Β  Β  Β  Β 4
Β
jkr_wrk
Forum|alt.badge.img+37
  • May 2, 2024 3:03 PM UTC
@sar_coppΒ Is this question still open?
I think your data looks pretty good for an excel pivot table to get the results you want.
But this will give the result in fme:
Β
sar_copp
  • May 2, 2024 3:40 PM UTC
Β
I am indeed looking for the answer - my excel screen print was just an illustration of what I need, havent managed to achieve it. Will look at what yo’ve done
