Transparency issue while transforming OBJ to GLTF.
  • April 8, 2020
  • 22 views
I tried converting a OBJ to GLTF.It got converted properly.But the gltf output is transparent.
the mtl of OBJ is:
newmtl texture
Ns 26.4
d 1
illum 2
Kd 1 1 1
Ka 0.2 0.2 0.2
Ks 0 0 0
and the gltf output material is :
"materials" : {
"mat_0" : {
"name" : "texture",
"extensions" : {
"KHR_materials_common" : {
"technique" : "PHONG",
"values" : {
"ambient" : [ 0.2, 0.2, 0.2, 1 ],
"diffuse" : "t_0",
"specular" : [ 0, 0, 0, 1 ],
"shininess" : 128
"transparent" : true
The transparency of the gltf is set true by default.How to change this while conversion.I dont want the model to be transparent.What could be reason for by default transparency of the model.How to change this.I cant share the entire data.
nampreetatsafe
Forum|alt.badge.img+13
Hi @san!   A colleague of mine suggests that the
transparent
 flag is set to true set because the texture likely has an alpha band. Converting the texture to a jpeg should result in this flag being removed. However, it is tough to modify a texture which is already on a feature. Some combination of SharedItemXXX transformers (i.e. SharedItemRetriever, SharedItemAdder, etc.)  and a
RasterBandRemover
 would be required. Hope this helps!
