Transform values from an attribute into a list
  • Dec 17, 2024 5:57 PM UTC
  • 592 views
willydevera
Forum|alt.badge.img+10
I need help.
I have an attribute column X with string values ‘S001’, ‘S002’, ‘S003’, and ‘S004’, all lined up in 1 column with 4 rows corresponding to the string values.
I would like the output Y should to be a single row list, having just one column and one row, containing the four values:
Y = (‘S001’, ‘S002’, ‘S003’, ‘S004’)
Could you please advise how this could be done in FME Form. Greatly appreciated.
Thanks,
Willy de Vera
dustin
Forum|alt.badge.img+36
  • Dec 17, 2024 6:12 PM UTC
It sounds like the Aggregator transformer would be helpful. It has a Generate List function. It also has the ability to create a concatenation. If you go the concatenation route, you would need to rename ‘X’ to ‘Y’ using an AttributeRenamer after the Aggregator.
willydevera
  • Dec 20, 2024 4:24 PM UTC
Thanks ​@dustin it works!
