TIN surface - filling the gaps
  • Jun 23, 2025 1:47 PM UTC
  • 143 views
harmen
Forum|alt.badge.img+10
Hereby a short description of my workflow with the questions at the end.
I have created a TIN from points. (TINGenerator)
Then clipped it with polygons (water area). (Clipper)
The water polygons have been lowered to -1 meter with the 3DForcer.
With a Junction I collect both the water (3D Polygon) and the TIN (surfaces).
Here are my questions:
  1. how do I properly merge those geometrytypes together?
  2. how do I fill up the (vertical) gaps between the lower water and the surface.
I tried many transformers and different steps, but as you can guess, with no results.
Using: FME2024.1
itsmatt
Forum|alt.badge.img+48
  • Jun 23, 2025 8:11 PM UTC
Have you tried the “BRepSolidBoundaryCreator.Beta” Custom Transformer.
This works pretty well - just give it the TIN and the height of the base (e.g., -1) and it should give you nice “walls".
harmen
  • Jun 24, 2025 6:29 AM UTC
thanks ​@virtualcitymatt for the suggestion!
It helps me to create the output the client wants… but you know me, I like to push it a little further.
So, what I actually wants is to fill the gap between the surface geometry on one hand (gray in the picture below) and the plane geometry polygons (with z-values) on the other hand (blue in the same picture).
Any ideas?
itsmatt
  • Jun 24, 2025 7:44 AM UTC
I think in this case you would just feed in each separate TINSurface into the its own feature and then set the BRepSolidBoundaryCreator.Beta to -1. You can then just skip out the Bottom output features.
This does assume that the “Plane” geometry with the -z values is flat
