there is a way to make a published parametre for the table qualifier of postgis writer ?
  • December 4, 2015
  • 8 replies
  • 28 views
hi,
is it possible to make a published parametre for the table qualifier of postgis writer ?
thx a lot for ur help
have a Nice day
Best answer by takashi
You can create a user parameter from the menu button beside the Table Qualifier field in the writer feature type properties dialog.
Takashi
  • December 4, 2015
I haven't tried, but perhaps inserting something like this could work
$(MY_PUBLISHED_PARAMETER)
David
  • December 4, 2015
Takashi
  • December 4, 2015
David
Hi David,
Thx for ur answer but it doesnt work :/
best regards
  • December 4, 2015
Hi Takashi,
thx for ur answer but there is no way to make a user parametre in my writer :/
Which version of FME u have ?
best regards
  • December 4, 2015
David
Sorry for my last msg ! it WORK :)
Thank u David
Best regards
  • December 4, 2015
Hi Takashi,
best regards
oh, you are using FME 2015.0 or earlier? Although there isn't the menu button for the table qualifier field in your version, you can set a user parameter name to the field directly, as David mentioned.
In 2015.1+, the menu button has been added to the field.
erik_jan
Forum|alt.badge.img+26
  • December 4, 2015
You can always use a published parameter, fetch that into an attribute with a ParameterFetcher and use a Fanout to create the table by that name.
mark2atsafe
Forum|alt.badge.img+59
  • December 4, 2015
David
Hi David - I set Takashi's answer to accepted rather than yours, because that's the way it should be from now on I think.
