The error number from ArcObjects is: '-2147155559'.
  • Mar 15, 2018 6:24 PM UTC
  • 8 replies
  • 447 views
yonasfme
I'm loading data (450k polygons) from FGDB into SDE. Versioning is enabled.The Transaction Type is a Versioned Edit Session and my Writer Mode is Insert. I have Drop Table as No and Truncate Table as Yes. The writing is very slow and after running for 3 hrs and 43 min the transaction failed with the following error:
An error occurred while attempting to start an edit operation. The error number from ArcObjects is: '-2147155559'. The error message from ArcObjects is: {Failure to access the DBMS server [08S01:[Microsoft][SQL Server Native Client 11.0]TCP Provider: The specified network name is no longer available. ] [sde.DEFAULT]}
Here is the log file:
Any idea why it is throwing that error?
Thanks.
Forum|alt.badge.img+63
Googling the ArcObjects error number doesn't seem to yield any useful results but the SQL Server one does come up with something useful. It all seems to indicate the network connection has been lost for whatever reason.
  • Mar 16, 2018 9:25 AM UTC
Edit sessions are notoriously slow. What happens if you manually truncate the feature class using e.g. ArcMap before running your workspace?
See also https://knowledge.safe.com/questions/35018/table-truncating-takes-ages.html
yonasfme
  • Mar 16, 2018 8:11 PM UTC
Thanks for your ideas guys but the loading is now completed successfully!
What did I do to make it work? Not much. I had multiple SDE writers in the workspace so I removed all except the one that writes the 450k polygons. I have also added the ArcSDEGrid Snapper transformer to simulates the ArcSDE conversion on each feature by performing ArcSDE translation, scaling, and coordinate snapping. It took 4 hrs and 14 mins!
I have created a ticket to find out why it took that long and how we can improve the speed. Will update when I hear back from Safe.
Thanks.
yonasfme
  • Mar 16, 2018 8:13 PM UTC
We trying not to do any manual work as we have a lot of datasets to be loaded to the SDE.
yonasfme
  • Mar 16, 2018 8:15 PM UTC
That's interesting because other writers on the same workspace loaded a relatively smaller number of records successfuly to the same SDE.
yonasfme
  • Mar 20, 2018 6:21 PM UTC
Here is an article recommend by Safe support for the possible reasons of the slowness of the workspace and its workaround:
https://knowledge.safe.com/articles/51216/editing-versioned-geodatabases-using-sql.html
Just want to share with the community and see what you think about it.
Thanks.
fmelizard
Forum|alt.badge.img+22
  • Mar 20, 2018 7:30 PM UTC
Thanks.
Thanks @yonasfme
In particular the issue is related to the truncate.
"The reason we cannot do an explicit truncate is that the versioned table we are interacting with is, in fact, a view. Views are unable to be truncated. As such, we have to use a different command to perform the truncate."
yonasfme
  • Mar 26, 2018 9:04 PM UTC
Thanks @yonasfme
Thanks @MattAtSafe
