Text line aggregation
  • October 28, 2016
  • 7 replies
  • 237 views
davideagle
Forum|alt.badge.img+21
Hi All,
I have a text file with a variable quantity of lines, separated by an empty line. The lines adjacent to one another need to be grouped together and then concatenated. So for example:
Test1
Test2
Test3
testy1
testy2
test
(where the hyphens are the blank lines, I can't format this page with return lines it seems)
Would need to become:
Test1 Test2 Test3
testy1 testy2
test
I've tried to do this a couple of ways so far, and variables seemed to be the right choice initially but now I'm not so sure. As I also have a format attribute on each line that contains the text_line_length, I was trying to use this as the delimiter when it was = to 0. It's interesting because the logic is a bit like using the PointConnector to create line geometries and what I need is to use the text_line_length as the 'connection break attribute'. Anyway, that's a digression. Does anyone have any simple tricks I could deploy to do this?
Thanks, Dave
revesz
Forum|alt.badge.img+15
  • October 28, 2016
Hi Dave
What I would try:
  1. Read the file as text line.
  2. Trim the lines.
  3. Get rid of empty lines: simply by Attribute has a value / Attribute Is Empty String.
  4. StringSearcher: extract the digits from the end using the RegExp \\d+$ (\\d: digit, +: any number - of digits, $: at the end)
  5. Copy the original string to a new attrib
  6. With StringReplacer (or other way) replace the extracted digits from the copied attribute
  7. (Sort if you need to)
  8. Aggregator: group by this new attribute, concatenate the original string attrib.
Is this what you mean?
Cheers,
András
davideagle
  • October 28, 2016
Ok, I persisted with Variables and sorted it out.
Test for a blank line, send this to the counter and then set a variable to the count value. On the failed port of the Tester, use a VariableRetriever to get the count value and glue it onto the features that pass through. Everytime a row with nothing on it is seen, the count ID increments. Then just use the Aggregator to group on the count ID and do the concatenation.
Thanks for listening, I helps to talk it through :0)
Forum|alt.badge.img+49
I had a different approach:
Replace empty lines with a character that won't occur in your dataset, then aggregate them all and specify that they should be concatenated, split on that character, explode the list, cleanup a bit et voila! Hope this helps.
concat-text.fmwt
Forum|alt.badge.img+38
  • October 28, 2016
I'd assign a value to the blank lines and then use the adjacent feature support in the attribute creator to increment a group number after every blank line, then aggregate/concatenate based on this value
  • October 28, 2016
Hi @1spatialdave, assuming that a newline is represented by two special characters - [CR] (\\r) and [LF] (\\n), this might also be a possible way.
  1. Text File reader: Read whole file at once.
  2. StringReplacer (1): Replace two consecutive newlines i.e. [CR][LF][CR][LF] with a specific special character e.g. [BEL] (\\a).
  3. StringReplacer (2): Replace every remaining newline with a white space.
  4. StringReplacer (3): Replace the special character [BEL] with a single newline.
gio
  • October 28, 2016
@1spatialdave
If spaces are the only criteria...
..i'm pretty sure this question or similar has been sked before.
My workspaces-collection has bunches of variableretriever/setter variants..
davideagle
  • October 28, 2016
The moral to the story is that the FME User community is awesome and... there's 14 ways to do anything in FME. Thanks all very much, neat solutions.
