Text File Writer: is it possiblle to set the filename from an attirbute value?
  • Aug 21, 2020 9:26 AM UTC
  • 47 views
davtorgh
Forum|alt.badge.img+12
Hi everyone,
this should be a simple thing to do, but I can't find how (or even it is not possible).
Thanks!
Best answer by ebygomm
Yes, you can set it in the Navigator panel
Capture
Forum|alt.badge.img+54
  • Aug 21, 2020 9:34 AM UTC
Capture
davtorgh
  • Aug 21, 2020 9:58 AM UTC
Capture
Thank you @ebygomm​ ,
very simple solution| :-) I usually use fanout to split the output into several files, it didn't occur to me to use it for one file only.
