Text file reader
  • September 14, 2014
  • 6 replies
  • 42 views
Hi Everyone,
I've a little question to ask, How do I read a list of files from a text file (Throught text file reader), which is placed in the parent folder of another data reader in the same workspace.
I can do it manually, but I want the text file reader to automatically read a certain file from the parent folder. The attributer creater is not willing to expose my created attributes as private/public variable, which i wanted to use as an input to Text file reader.
Thanks
Best answer by david_r
here's a short Python scripted parameter that will return the parent directory of another published/private parameter:
import os.path
filename = FME_MacroValues['MY_FILENAME']
return os.path.abspath(os.path.join(filename, os.pardir))
Assumes that there is a published/private parmeter called MY_FILENAME. The scripted parameter must appear BELOW this parameter in the Navigator pane (i.e. order of execution).
David
  • September 15, 2014
as you discovered, you cannot set the value of of a private/pubilc attribute from within the workspace, they're effectively read-only as long as the workspace is running.
Perhaps you should look into Python scripted parameters, where you can write a Python script that calculates this values when the workspace starts, e.g. on the basis of other (static) parameters.
David
gio
Forum|alt.badge.img+15
Or use a filewriter to write your dynamicaly created attributes after u used attributeexposer on them, then workspacerunner to call filereader.
I can set the Source Text File (Text file reader) to a Published attribute, the problem lies in getting the parent Folder. I also can do it by using FileNamePart Extracter. Just not able to expose the extracted Features as Public / Private parameters.
Thanks.
gio
If u are talking setting parameters during runtime..that can only be done using phyton or tcl etc. (there is a forumtopic somwhere thiss late june/july somewhere)
If u are talking attributes, this can be done using attributeexposer==>featurewriter==>featurereader combo. I have posted a neat script to accomplish this. Or there are some posts using phyton to do same.
import os.path
David
  • September 16, 2014
Thanks David, by using python script provided by you, I created what I wanted. Thanks a lot.
