tab file output with missing attributes
Best answer by ian_mitchell
apologies - you'll need a bit more info ... I am processing Ordnance Survey Meridian data ... supplied as zipped TABs
part of my processing isolates a single feature processes the attributes and writes it out ... my processing exposes some of the hidden MapInfo text attributes and writes to visible attributes with their name changed ... I take the foreground colour attribute and swap the R and B values so RGB becomes GBR
however - when I write the feature out to a new TAB my "exposed" text attributes are ignored ... they're not defined in the TAB file even though I defined them (as INTs) in the Writer
any ideas?
many thanks
IanM
