String replace with multiple value result.
  • November 24, 2022
  • 6 replies
  • 409 views
kidega
Forum|alt.badge.img+8
I have a scenario with a random string test;
"Häradålderön" which my goal is to se the result to "Haradalderon".
Basically replace any [ä, å, ö] with [a, a, o] letter.
I guess using regular expression could do it, but I find it tricky since it might be three sequences to search for ä, å, ö. Any ideas appreciated!
  • November 24, 2022
Did you have a look at the StringDiacriticRemover from the Hub? I believe it should do what you're looking for: https://hub.safe.com/publishers/safe-lab/transformers/stringdiacriticremover
Forum|alt.badge.img+46
  • November 24, 2022
Have you looked at the StringPairReplacer?
kidega
  • November 24, 2022
Haven't looked into this yet, thanks for the suggestion!
kidega
  • November 24, 2022
Great! This was a very easy solution, thanks!
pradip
Forum|alt.badge.img+3
  • June 29, 2023
kidega
  • July 28, 2023
