Standalone = Yes is missing in FME generated file
  • Nov 17, 2025 7:05 PM UTC
  • 213 views
aashnaparikh
Forum|alt.badge.img+3
Why does XML header of the FME generated file displays the XML header as <?xml version="1.0" encoding="UTF-8" > instead of <?xml version="1.0" encoding="UTF-8" standalone="yes"?>
Best answer by kailinatsafe
Hello ​@aashnaparikh, thanks for posting! The standalone declaration is an optional XML header attribute, and it’s not something we currently generate. You can add it using XMLTemplater by writing a custom header in the ROOT section. Just make sure Write XML Header parameter is set to No.
If you’re able to share how the XML is being generated, I can look into adding a parameter to support the standalone declaration in the tool. Happy to help, Kailin.
kailinatsafe
Forum|alt.badge.img+24
  • Dec 8, 2025 10:06 PM UTC
danilo_fme
Forum|alt.badge.img+58
  • Jan 1, 2026 11:32 PM UTC
It’s a nice answer ​@kailinatsafe
