SQL to Run After Writer in both SQL Spatial (JDBC) and SQL Non-Spatial writers
  • Mar 3, 2020 3:50 PM UTC
  • 195 views
kuanglee
I have 2 dynamic writers in which data are coming from 2 readers (SQL Spatial and SQL non-spatial, respectively). Actually the readers are reading from the same database (A, for example) and the writers are writing out to the same database (B, for example). The reason why I have 2 readers is because there are spatial data and non-spatial tables in database A.
I have a SQL script that can set ObjectID to Primary Key. It doesn't seem working properly when I put SQL script into the first writer (spatial). Therefore I had to put this SQL script into the second writer (non-spatial) to make it run properly.
Any ideas? Thanks
Best answer by kuanglee
Thanks for your suggestions. It turned out that I don't need this FME_SQL_DELIMITER $ in the JDBC writer's SQL Editor (SQL To Run After Write).
erik_jan
Forum|alt.badge.img+26
  • Mar 3, 2020 4:34 PM UTC
Another option is replacing the writers by FeatureWriter transformers.
Then you have the option to use a SQLExecutor transformer after the FeatureWriter is done.
Hope this helps.
kuanglee
  • Mar 3, 2020 10:20 PM UTC
Hope this helps.
Thanks for your suggestions. It turned out that I don't need this FME_SQL_DELIMITER $ in the JDBC writer.
kuanglee
kuanglee
