sql server timestamp read as a buffer datatype
  • August 14, 2024
  • 55 views
thomastupuivao
I have a set of records that read via SQLExecutor which includes a timestamp field (driver_date). This seems to be stored a “buffer” datatype.
I don’t seem to be able to explode this field using the DateTimeExploder as it can’t autodetect the timestamp value as a date/time value.
I’ve tried including a DateTimeConverter, but get the same result. Is there someway to convert the timestamp from “buffer” datatype to datetime?
Best answer by _jacques_
Hi!
If you just want to change the datatype you could use an AttributeManager and change the datatype to datetime.
However I think you could tweak the input format field in the DateTimeConverter to fit your format: %d/%m/%Y %H:%M:%S.
Best regards,
Jacques
_jacques_
Forum|alt.badge.img+15
  • August 14, 2024
Hi!
Best regards,
Jacques
thomastupuivao
  • August 14, 2024
Thanks, that works!
