SQL Server Execute SP, then reader from output table is locked
oliver.morris
Forum|alt.badge.img+12
I have been using the sql executor to run a sql server stored procedure which populates a table, I then try to use a feature reader to read from the table that has just been populated. Alas it times out. If I do either of these components separately it works leading me to believe FME is holding the connection open to sql server and creating a lock on the table, so that when the reader tries to read it can't. I am using the SQL Server JDBC Client. I will try with the Native Client but this will mean I can't use it with fme cloud which is what it is intended for.
Has anyone else had this issue? Working log and failing log are attached.
Many Thanks as always
Best answer by ravenkopelman
Hi @olivermorris,
Try adding a COMMIT after your stored procedure invocation.  For example, your SQLExecutor would contain something like the following:
FME_SQL_DELIMITER ;
EXEC	[dbo].[SP_API_EXPORT_PS_SR]
		@modules = ...;
COMMIT;
Note the semi-colon after your EXEC.  The explicit commit will hopefully release any locks obtained by the stored procedure.
(In general, SQLExecutor doesn't auto-commit anything to allow manual control over transactions.)
oliver.morris
  • April 26, 2018
Wwith the feature reader I think it is JDBC only so I dont think I can use the native client driver in any case.
ravenkopelman
  • April 26, 2018
Hi @olivermorris,
FME_SQL_DELIMITER ;
		@modules = ...;
COMMIT;
oliver.morris
  • April 27, 2018
ravenkopelman wrote:
Hi @olivermorris,
FME_SQL_DELIMITER ;
		@modules = ...;
COMMIT;
perfect that did the trick, thank you
