SQL Script of MSSQLServer tables creation from Shapefile migration
  • Jun 28, 2018 3:05 PM UTC
  • 77 views
lianaolianov
Forum|alt.badge.img+5
Hello community,
I'm storing some shapefiles in a MSSQL Server database.
How can I get the SQL script FME used to create the database and populate it from the shapefile ?
Thank you
fmelizard
Forum|alt.badge.img+22
  • Jun 28, 2018 3:22 PM UTC
Hi @lianaolianov, are you wondering what sort of INSERT statement FME is using to write your shapefiles to your SQL Server database?
lianaolianov
  • Jun 28, 2018 5:46 PM UTC
Yes exactly
fmelizard
  • Jun 28, 2018 6:52 PM UTC
Hi @lianaolianov, thank you for clarifying your question! You can set up a trace on your database that will show you all of the SQL commands that have been sent to it. It's here that you'll be able to see all of the INSERT statements. This might be something that you'll have to ask your DBA to set up for you.
lianaolianov
  • Jun 29, 2018 10:18 AM UTC
Thank you very much for your answer. It's the first time I hear about this technique. How can I set up it ?
