Splitting and pairing attributes across two different fields then test results
  • Feb 12, 2026 5:28 PM UTC
  • 95 views
mattenvsys
Forum|alt.badge.img+4
Hi there,
I am assessing a dataset for changes that took place since 2012. This data contains these two fields of interest:
  • change_date
  • reason_for_change
change_date contains multiple dates that a separated by a comma and reason_for_change contains strings of change types separated by a comma.
An example of the data structure is
Feature 1:
change_date: 2016-10-20
reason_for_change: New
Feature 2:
change_date: 2009-06-15, 2013-09-04, 2016-10-05
reason_for_change: New, Attributes, Modified
Feature 3:
change_date: 2010-09-11, 2014-04-09
Is it possible within FME to pair each individual reason for change to a change date and then test if it matches the follow conditions of reason_for_change = New or Modified and change date greater than 2012-12-31?
Using the three examples above, feature 1 and 2 should be highlighted as a change since feature 1 is new in 2016 and feature 2 had it’s geometry modified in 2016.
So far I have used a Attribute Splitter on each field to split by comma. But then I’m not sure where to go from there with the resulting lists. Do I need to first check the max number of list elements then manually expose ‘n’ number of list elements into new paired attributes? For example date1, change1, date2, change2, date3, change3. Then perform a test on each one of those pairs or is there a more elegant way of exposing the correct number of list elements?
Thanks
Best answer by geomancer
Certainly you can.
  • Make sure each feature has a unique number
  • Make 2 branches: one to process the dates, one to process the reasons
  • Join the branches
  • Test on changes
See the attached workspace (FME Form 2023.1).
geomancer
Forum|alt.badge.img+71
  • Feb 13, 2026 8:24 AM UTC
Certainly you can.
  • Join the branches
  • Test on changes
  • Feb 13, 2026 8:37 AM UTC
In my opinion this is easiest done with a few lines in a PythonCaller:
def input(self, feature: fmeobjects.FMEFeature):
dates = [
x.strip()
for x in (feature.getAttribute("change_date") or "").split(",")
if x
reasons = [
x.strip()
for x in (
feature.getAttribute("reason_for_change") or ""
).split(",")
if x
feature.setAttribute("changes{}.change_date", dates)
feature.setAttribute("changes{}.reason_for_change", reasons)
self.pyoutput(feature, output_tag="PYOUTPUT")
You’ll want to expose the list attributes “changes{}.change_date” and “changes{}.reason_for_change”
Example result:
mattenvsys
  • Feb 16, 2026 2:39 PM UTC
That’s brilliant. Thank you for helping with this
