Split JSON into several features
  • May 30, 2017 3:01 PM UTC
  • 573 views
oscard
Forum|alt.badge.img+23
Hi.
I have the following .json file:
"0": {
        "0": {
            "Group 1": {
                "Sub 1": 0,
                "Sub 2": 70
            "Group 2": {
                "Sub 3": 0,
                "Sub 4": 29
            "Group 3": {
                "Sub 5": 136,
                "Sub 6": 120
        "1": {
            "Group 1": {
                "Sub 1": 0,
                "Sub 2": 76
            "Group 2": {
                "Sub 3": 1,
                "Sub 4": 35
            "Group 3": {
                "Sub 5": 157,
                "Sub 6": 115
"1": {
        "0": {
            "Group 1": {
                "Sub 1": 5,
                "Sub 2": 72
            "Group 2": {
                "Sub 3": 51,
                "Sub 4": 2
            "Group 3": {
                "Sub 5": 16,
                "Sub 6": 20
        "1": {
            "Group 1": {
                "Sub 1": 50,
                "Sub 2": 7
            "Group 2": {
                "Sub 3": 17,
                "Sub 4": 3
            "Group 3": {
                "Sub 5": 17,
                "Sub 6": 15
The JSON Reader of FME reads it like a single feature with 2 attributes:
What I want to do is split that feature into 2. One has to have the attrbiute "0" and the other one, the attribute "1". Instead of a feature with two attributes, I need two features with one attribute each.
Is that possible? I have made a mess with JsonExploders, JsonFlatteners and friends... but no luck so far.
Thanks for any help provided!
FME Desktop 2016
Best answer by takashi
Hi @oscard, I would read the JSON document with a Text File reader (Read Whole File at Once: Yes) and then fragment the document with a JSONFragmenter.
mygis
Forum|alt.badge.img+14
  • May 30, 2017 3:21 PM UTC
Hi @oscard,
If you are using FME Desktop 2017, you can do that from the reader's property. It is easy and straightforward. Check the attached screenshots.
I hope this helps.
oscard
  • May 30, 2017 3:24 PM UTC
Hi @oscard,
I hope this helps.
I'm using 2016 :(
  • May 31, 2017 11:31 PM UTC
oscard
  • Jun 1, 2017 5:57 AM UTC
That's what I want!
Thanks!! It's a pretty simple solution. I need to think outside the box when reading files. I was being stubborn with the JSON Reader.
