Split Json file from GeoJSON files
Hi!
I am converting GIS data to GeoJSON files. Currently the GeoJSON files are within the JSON file. Is it possible to separate the JSON file so I can see the GeoJSON files along with the JSON file. Essentially, it would look like the image attached.
Thank you for any help!
David
  • April 18, 2018
Hi @david_prosack88, looks like you attempt to create individual GeoJSON datasets corresponding to each feature type in the source GIS dataset. If so, I think you can directly create desired GeoJSON files using a GeoJSON writer with Fanout Dataset configuration. See here to learn more about the Fanout: Separating Output Data with Fanout
If you want to know a way to split an existing JSON document containing GeoJSON objects into individual GeoJSON parts anyway, please explain the structure of the JSON document specifically.
Thanks for the response @takashi. I've been trying to separate the GeoJSON files using the fanout dataset configuration, but I cannot get the expression to work. I tried separating by feature name, but I just get file extensions. How can I separate by extension? Such as .geojson.
Thanks,
David
  • April 19, 2018
You can set any file extension in the Fanout expression. For example, if an attribute called "fme_feature_type" stores your desired destination feature type name (i.e. file name without extension),  this Fanout expression should work as expected.
@Value(fme_feature_type).geojson
