split combined lines
  • December 31, 2019
  • 15 views
charry
Forum|alt.badge.img+5
Every two lines combined in my shp, I want to split, how I shoud do?
charry
  • December 31, 2019
I want Split into single lines,,Like the example above?Split into 5 single lines
Forum|alt.badge.img+62
It's not quite clear what you're looking for. What exactly is your input? Can you share a sample here?
  • January 3, 2020
@charry You probably need to include a zip file with a small sample of the data so that members of the forum can understand what you're attempting to accomplish.
If you have a Esri Shape multi-line geometry, you can probably use the Deaggregator transformer to break the parts into separate features.
  • January 6, 2020
I think you are looking for the LineOnLineOverlayer Tool. It will split apart crossed lines into individual features.
