SpatiaLite questions
  • October 10, 2017
  • 45 views
jorge_rosales
Forum|alt.badge.img+8
I need generate a SpatiaLite database that stores a 1:n relationship. The 1 side is a spatial table and the n side is a non spatial table. Firstly I create a template (template.sqlite from template.sql).
If I use only the SpatiaLite writer I get an error with the non spatial table (test1.fmw). Maybe I misunderstand the meaning of wkb_none. If I use a SpatialLite writer for the spatial table and a Sqlite for the non spatial table, everything runs ok but it seems that FME ignores an existing constraint in the template database (test2.fmw).Workspaces: Source data: https://goo.gl/5FfJBs
Best answer by pallegama
Hi @j4,
Looking at the SLQITE3 writer parameters, I noticed that 'Template File' parameter has not been set properly. Could you please set this parameter and try again.
Regards,
Priyantha
pallegama
  • October 11, 2017
Hi @j4,
Regards,
Priyantha
jorge_rosales
  • October 11, 2017
Hi @j4,
Regards,
Priyantha
Both writers point to the same destination file so if you use two templates files (one per writer) the second will overwrite the database (and data) created by the first one.
pallegama
  • October 13, 2017
Hi @j4,
I found the exact cause for this issue. Unfortunately, I don't have required ArcGIS license to test the workspace with your original input. However, this should resolve the issue.
To identify the issue, I have created sample spatial data (ffs) file and attribute data (csv).
The issue is you have to enable the Foreign key constraint in Sqlite in run time passing the command 'PRAGMA foreign_keys = ON'. ( Please find more information in this regard in the link https://sqlite.org/foreignkeys.html).
This can be achieved in FME by passing this command to 'SQL To Run Before Writer' parameter in the Sqlite Writer as depicted in the image below.
To test the workspace, please run it with provided CSV file which contains a FK value violating the constraint. This should fail the worksapce.
Then remove the last record of CSV file (which violate the FK constraint) and run the process again. Then it should run successfully.
spatialite.zip
jorge_rosales
  • October 16, 2017
Thank you @pallegama, it works. Maybe the "PRAGMA foreign_keys = on" should be the SpatiaLite Writer default behaviour. I think it would be clearer.
