Spatial Join to just populate one field
  • Apr 25, 2019 3:38 PM UTC
  • 138 views
I am trying to populate one attribute field (Main) based on a spatial relationship in a file geodatabase. I have mains and laterals. Our mains have a field called "Main_ID". I want to populate our lateral attribute field "Main" based on the main that the lateral touches. Seems like a pretty simple problem. I've tried the spatial relator, but that actually adds the geometry (essentially doubling the number of laterals). I don't want to write out or replace any geometry, just populate that one attribute field.
Any suggestions?
erik_jan
Forum|alt.badge.img+26
  • Apr 25, 2019 3:41 PM UTC
I would use either SpatialFilter (merge the attributes and if necessary first remove all attributes except the ID from the main) or the NeighborFinder (same setting).
  • Apr 25, 2019 4:03 PM UTC
@erik_jan Thanks. That sort of worked. I got it to add the attribute, but it is still writing features, so now I have duplicate laterals, one with the main field populated correctly and one that is still blank. How do I get it to just populate the attribute, not write out another feature?
erik_jan
  • Apr 25, 2019 4:11 PM UTC
How do you write your data?
You can use the Feature Operation on the table, set to Update to update the existing laterals based on ID.
  • Apr 29, 2019 8:37 PM UTC
@erik_jan - I still cannot seem to get this to work 100%. I used the NeighborFinder on the lateral/main union and that works great now, but for the lateral/parcel one I need to use the intersect predicate. It runs, finds everything, and says it is writing, but nothing does write. I have sent it to support, but wanted to post it here in case anyone else has run into it.
Thanks for your time.
