When trying to upsert a large dataset I get the following error:
Socrata Writer: Failed to Execute `""C:\\Program Files\\FME\\jre\\bin\\java" -Xmx1g -jar "C:\\Program Files\\FME\\plugins\\socrata\\datasync.jar" -ph true -sc "C:\\Users\\dmingl\\AppData\\Local\\Temp\\FME_1533665505412_4848\\control.json" -i u8yq-kcrr -c "C:\\Users\\dmingl\\AppData\\Local\\Temp\\FME_1533665505412_4848\\config.json" --userAgent "FME/2016.7.23.16717" -f
I'm using DataSync 1.7
Hi @dmingl - If you're a Socrata customer, you can open a support ticket with Socrata's Support team by emailing support@socrata.com
If not, can you please share more of the log? Namely from where the socrata writer initiates to failure.
I already did. They weren't any help.
Hi @andrewming.
Sharing a few more details will help the FME community help you. Please reply to this thread and provide additional details including:
  • A clear statement of the problem you are trying to resolve
  • The version of FME you are using, including build number and edition
  • The version of Socrata you are using and any other applications
  • A small sample of your data, or screenshots of the data in the FME Data Inspector
  • A description of your expected output, with screenshots if possible
  • Your FME workspace
  • Your FME translation log file
  • Any other information that may be useful to share
